- strange behavior with jce editor and sp pagebuilder
Have some strange behavior with jce editor and sp pagebuilder.
403 error in front end editor and double editors in backend translations.
When using tiny editor bug are gone, but I really like to use jce
Been reading other topics, is this an option (if yes, how?)
" Better to leave the file as it is, and delete the administrator/components/com_jce/includes/loader.php file, as it is no longer used in JCE Pro 2.7.15 "
Using jce pro 2.7.15 pagebuilder3.6.1 joomla 3.9.10
Pas
Pas
The file in question should be removed when JCE Pro 2.7.15 is installed, but for some reason it does not appear to have been on your site. Also, SP PageBuilder 3.6 does not attempt to load the loader.php file, so I am not sure why this error is being generated in the first place.
Nevertheless, the best course of action here might be to uninstall JCE Pro, and re-install. To do this:
1. Go to Extensions -> Manage -> Manage
2. Click Search Tools and set Select Type to Package.
3. Check JCE Pro Extension Package and click the Uninstall button.
4. Download and install JCE Pro 2.7.15 - https://www.joomlacontenteditor.net/downloads/editor/pro/latest
Thanks Ryan,
Did reinstall. Guess i'm a step closer after reviewing this.
In short, frontend editor wouldn't save if second slide title is using </br>
Trying some variants....
<p>Imagine having more time<br />to</p> works
<p>Imagine having more<br/> time to</p> error
Is it possible the editor reacts on 'more' ?
Pas
Pas
I"m not seeing this error in my tests. Please send me a login - https://www.joomlacontenteditor.net/contact/site-login
