  1. stoeltje
  2. JCE Editor
  3. Tuesday, 23 July 2019
Is there any possibility in inserting another 'read more' than the actual button?
I mean one which directly follows the end of text before read more, like
"to discover new ideas and outlooks, and to share in —>
or
to discover new ideas and outlooks, and to share in -read more->
Thanks in advance for your reply,
Ronald
JCE does not create the read more link / button, it only allows you to place a marker in the content where the read more should be created, which is done by the Joomla Article Manager when the article is rendered in the front-end.
To change the final position of this button, you would need to create a template override of the blog_item page - you can read about template overrides here - https://www.joomlashack.com/blog/joomla-templates/customize-your-joomla-templates-by-learning-overrides/ - and a layout override of the readmore itself.
  1. more than a month ago
  2. JCE Editor
  3. # 1
Thanks I'll work on it
  2. JCE Editor
  3. # 2
