#100220 Gaps between Paragraphs and Custom Classes
Latest post by spaabus on Thursday, 13 June 2019 19:38 BST
spaabus
In my editor there are gaps between my paragraphs and headlines that don't represent how it is going to look on the front end. How do I get rid of those gaps in the editor? Also, I have some custom classes in my Joomla Template. How do I get those to show up as options like the "Format" dropdown shows the "h" tags?
Please post a link to your site so I can see what css files the template is using.
spaabus
Makes sense. The site is http://www.stunewslaguna.com and http://www.stunewsnewport.com. Thanks.
On both sites you have a file in the template css folder called editor.css which contains:
@import url(template.css);
body {
	/*font-family: Arial, Helvetica, sans-serif;*/
	margin: 10px;
	background: white;
	color: black;
Edit this file, so it includes @import rules for the other css files loaded in the front-end, ie:
@import url(bootstrap.css);
@import url(custom.css);
body {
	margin: 10px;
	background: white;
	color: black;
spaabus
That worked. BRILLIANT.
:D
